svd85
- December 28, 2014
- Boston, Massachusetts
- 2007 Ford Explorer
Hello. I just pulled all the spark plugs out of my 2007 Ford Explorer V8 4.6l and read that I need to crank the engine to prevent hydrolock from the carb cleaner I used, although I don't think I used that much. Can I just disconnect the electrical connectors to the coil on plugs to disable the ignition system? I also have the electrical connectors to the fuel rail disconnected too. Should I be doing anything else? Couldn't find the answer from searching the forum. Thanks.
