Ratman720
- September 13, 2013
- Raymond Nh
- 97 Ford explorer 5.0 AWD
Hey Guys,
This is my first post here and I wanted to begin by saying this forum has been a phenomenal resource For attempting to fix my woman's beloved explorer. This will be long but I know in these things more info is always better than less.
So she has ( at least I think its this) a 97 ford explorer 5.0 AWD, Eddie Bauer. Were not sure exactly how many miles the odometer was stuck at 152k when she bought it.
In any case I have so far replaced the brakes and it needs new plugs but Im currently rebuilding the front end after a small problem.
After letting her know it needed new wheel bearings she took that to mean she should drive it anyways and it siezed up on the highway. Now we had heard the wheel bearings coming from the drivers side and what was originally just metallic noise became an incredibly loud high pitched whine on the highway.
due to some smoke appearing from what appears to be a loose brake fluid cap, Though it could have been the wheel bearing when we tried to get moving again there was a loud grinding noise, and even some sticking to the point where we couldnt get up to speed.
Got it towed home where I have completed the following repairs
Wheel Hub bearings (replaced)
Upper control arms (replaced one visibly had too much play)
sway bar in links (replaced one was visibly broken completely broken)
Rear E-Brakes (removed to be installed at a later point)
Front differential passenger side axle gasket (old one popped out right around when it stopped lots of oil leaking everywhere)
I have also inspected the following
Front axles (fine including splines)
Front CV joints (fine including splines)
Front calipers (fine)
Got the whole damn thing reassembled and what do you know still had a crazy grinding noise and a sticking (like it would feel if gears weren't interlocking properly). So I checked out the forums and there were some suggestions about removing the drive shaft as this can go bad. Because the splines were fine on both front axles it seemed reasonable enough.
So I pulled the drive shaft 4 torx bolts holding the universal and 4 12 point 12mm bolts on the rear towards the transfer case. Also oddly enough the transfer case is sealed up which is not reminiscent of what I was reading on the forums
The shaft looks fine as far as I could tell but the front spline leading to the differential was crazy loose. It could be moved by hand and could actually partially rotate somewhere between 90-180 degrees.
With the car as a rear wheel drive I tried backing of the ramps and the whole thing seized up after 6inches to a foot of movement. Hopped back under the vehicle while it was like that the universal joint/spline was also seized up. It will drive forward but not in reverse.
So I am left with a dilemma, we are currently down to her motorcycle as a form of transportation and frankly in new England that wont go all that much farther. My car has at least a blown head gasket (****ty mazda 6 im all kinds of pissed). So until I get some more reliable work Id rather not begin that project.
Here are my current thoughts.
A) the front differential gear set is very likely shot
b) I cant seem to pull the drive shaft spline
C) the truck is currently rear wheel drive.
Option 1
Temporarily removed the axles and CV joints for the front wheels until I have the time for options 2 and three, give her a rear wheel drive. Drain the differential fluid and pack the box to keep it clean. Make sure she chocks the wheels etc
Option 2
Locate, remove and install another differential from a junkyard.
Option 3
Rebuild the current differential with a kit. I found this one on amazon need to do more research to see if viable. Any insight would be appreciated
http://www.amazon.com/Precision-DRK...r=1996|1996&carId=003&n=15684181&s=automotive
Option 4
Hunt down a rebuilt or new differential and install it.
I was curious as to whether option 1 is safely feasible and ideally any advice on 3 or 4. let me know your thoughts i apologize for the length
Option 1
Option 2
Option 3
Option 4
