For the record, the tires are 36x13.50 Iroks, the paint is Rustoleum hammered black and hammered grey. I like the hammered paint because it dries super hard and sticks to anything- you dont have to have super clean and primered metal for it to hold. Knock the rust off, wipe it with mineral spirits and fog away.
BALANCING-
You can pretty much forget having these balanced at a tire shop. They are just too heavy. No biggie, as you can use several things inside the tire to balance it yourself. Golf balls, BB's, or airsoft pellets. The theory behind it is the same as the powder stuff- centrifugal force will sling the junk inside the tire to the lightest spot of the tire and it will self balance every time you take off. It really works. I chose the airsoft pellets for these reasons-
Golf balls are noisy at really low speed.
BB's will rust from the damp air inside the tire and possibly clump together or not roll right. There is a rumor going around that the BB's will tear up the inside of the tire. This simply is not true.
Going by the tire balancing chart, i needed 6-7 ounces to balance a 36" tire. But, that is concidering a stock steel or aluminum wheel. We've got weld on beadlocks, which add alot of weight. Each jar of airsoft pellets i used came up to 10oz, so i poured one jar into each tire. Too much isnt that big of a deal, it will spread out. Too little will not quite balance the tire.
If you use airsoft pellets, make sure to get the really dense ones, like the ones i have pictured below-
