- November 1, 2017
- Lebanon MO
- 93 Sport
With most of the drivetrain done on the 93 LSXplorer (The Black Pearl), I am working on the front driveshaft currently.
The transfer case is a np241 (going to swap in an ECOBOX next year some time), the 241 uses a companion flange on the front output. I replaced a front driveshaft at work cause the splines were stripped out of the slip yoke.
Cut the male slip stub shaft off the chevy shaft, did the same for my factory 93 sport and kept the explorer stub shaft.
Tack welded the driveshaft and stub shaft together, and i am a few inches too long at ride height. Not a problem, easier to remove some tube than to add more.
my question is, how much slip should i have in that front shaft? 30% compression, 70% droop? 50/50?
The female slip yoke (factory X) is about 4.25" long.
Ive got about 12 inch travel shocks up front.
I have the software to field balance the shaft (on vehicle), will use a dial indicator minimize/eliminate runout
