- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Hang in there! We need pics!!
Electroless nickel plating.Dang
I wish there was a dip you could just drop them in and it would add a layer of metal
I’ve been thinking a lot about your collectors
Maybe the best way to approach this would be to have the pipes pass through a piece of machined flat steel. With the ends cut flush (I know, not ideal for flow) you could weld the ends of the tubes to the downstream side of the steel plate. Then weld the rest of the collector housing and downpipe adapter circumferentially to the plate.
If you really want that converging spike type thing going on, make the cones/spike out of scrap tubing in an assembly (pre-welded together) and weld that assy to the downstream side of the plate before closing it all up.
It’s hard to explain…I really should fire up SolidWorks
But this would keep all of your welds inside the collector, with the exception of the exterior housing weld. No trying to shoot weld between pipes.
I don't, but it's on my list too. I've been looking for a while, but everything that comes up on marketplace is pretty pricey. Hopefully I can score a setup at a farm auction next spring.If you’ve got an oxy acetylene rig, you can gas weld too. It’s harder and less controllable than TIG (in terms of heat), but the technique is very similar and it’s cheap if you have access to bottles.
