arm1984
- July 1, 2013
- 2000 explorer
I have rounded off my fill plug for my rear diff. It has obviously never been removed and it probably never going to come out now. After reading on here I have a number of options.
1. Drill the plug try use an easy out extractor and hopefully get it out that way.
2. Buy a new diff cover with fill plug.
3. Fill via the ABS sensor.
Now neither of these are appealing as if 1. doesn't work I'll have swarf in the diff and have to drain with no way of filling 2. seems quite expensive. 3. Everything seems fragile and temperamental. If I do this I know it will break and never work again.
Option 4. Remove diff cover. Drill suitable size hole for 15mm female coupler plumbing fitting, fit and seal with sealant and use 15mm end cap to finish off. Question, is there enough clearance inside the diff to do this? If so cost will be about £3.
Any one done this? Any one got any other ideas?
