92FOX
- June 5, 2015
- Fort Riley, KS
- 2006 Mountaineer AWD
I've got a 2006 Mountaineer, 4.0 AWD with the 5R55S tranny in it. It has 146k on it, and have owned the vehicle for almost two years, since 117k. The transmission shifts good and has no slips. I have no idea the previous maintenance done on the vehicle before I bought it, only what I've done in the last two years.
My question is, do I need to change the transmission filter? I went to remove the center drain plug (the T35 inside the 22mm main plug) to look at the fluid, but it was seized and stripped out. I now have no way of knowing the quality/state of the fluid inside the transmission without removing the entire drain plug, draining everything from the pan.
I'm a preventative-maintenance kind of guy, so I really want to drop the pan, change the filter and replace the fluid drained, but I also know that this can cause damage if the transmission has some internal issues I'm not aware of.
Any advice would be awesome.
