TheWestMountain
- June 6, 2020
- Ann Arbor
- 2015 Explorer Limited
I am thinking about changing the automatic transmission fluid (ATF) on my 2015 Explorer Limited and have done some research. Almost everyone is saying “drain, refill, then check fluid level with the engine running”. However, the ATF cap is hidden under the air filter and I have to remove the air filter assembly first to refill it. This leaves it impossible for me check the fluid level with the engine running.
I am just thinking, if I add back the exact same amount of ATF as I drained (cold engine), do I really need to check the fluid level afterwards?
Seems like auto shop would use a machine to drain and fill back the same amount of fluid. Do they really check the fluid level after the refill? Does anyone know how does auto shops do transmission fluid change?
