Quxote
- November 3, 2009
- Philly, PA
- 95 XLT
I just bought a 1995 Exolorer XLT. Here are the problems I am having, hopefully someone will know what might be the problem.
1. Door Ajar light stays on
2. Power Mirrors dont work
3. Interior Lights stay on when door is closed.
4. Front blower for AC and heat does not always work (does sometimes)
5. Rear wiper does not move (but the washer fluid does pump out)
6. 4WD and 4WD Lo lights flash on the dash, vehicle does not go into 4WD when the switch is moved to Auto.
After searching the forum, I read somewhere that if the mirrors dont work, And the door ajar light stays on it might be the black wire inside the rubber boot between the door and the body, anyone have any other suggestions on how to figure out which door is causing the problem. I am thinking problems 1, 2, and 3 are all the same issue. I think #6 is also an issue cause the fuse for the int lights is pulled, which is the same fuse for the 4wd system
Problem 4, the front blowers come on sometimes. I noticed today when it was working, I wanted to switch the blower from feet to head, doing that passes the Off postion, as soon as I did that the blower stopped. Makes me think the switch is bad...anyone know how to test the switch?
Problem 5, the only thing I can think of is a bad wiper motor, I am gonna check the wires to see if they are getting power when the switch is on.
Edit: I just went to the truck and opened every door with the key in, each door makes a sound when the door opens, the passenger, and rear door make a long sound, the driver's door makes a ding ding ding sound (telling me the key is still in the ignition).
The rear tailgate and windoe do not make a sound when they are each opened, are they supposed to?
