  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Do you use Oil Treatment Additive for your Explorer ?
Mickalo
Location
NW., Iowa
Iowa
2010 Explorer w/4.0 4wd
Among my "toys" is a 900-horsepower '67 Camaro 1/4-mile drag-race car. I've been racing this car with the same engine since 1999. Every winter, my buddies and I tear it down for a close look at rings and bearings. We've never replaced either because we can't detect any wear. The motor oil we use is Mobil 1 5w30 WITHOUT any additive. We buy our Mobil 1 motor oil at Walmart.
now that's a beauty even if it is a chevy :) :)
Exit32
Location
Boston, Mass.
2020 Explorer Platinum
From a standing start how does your Explorer fare against the Camaro?
I've never raced my Platinum, but ...
According to Edmunds, my 2016 Explorer Platinum equipped with the 3.5-liter Ecoboost engine will run the 1/4 mile in 14.6 seconds at about 95 mph. My 406 cubic-inch, small-block '67 Camaro runs the 1/4 mile in 9.03 seconds at about 149 mph. So, the Camaro would win easily.
BTW, the Camaro is street legal.
JETZ
2012 Explorer Limited
Mobil One full synthetic in my Limited, Bimmer, and Z16 Vette.
Black Eyed
Location
Saudi Arabia
Riyadh
Explorer 2015 base model
I used the STP oil additive about 40 years ago. Here is what your 2015 Owner's Guide says about oil additives;
Do not use supplemental engine oil additives. They are unnecessary and could lead to engine
damage that is not covered by your Ford warranty.
if its truly makes the engine live longer, of course all manufactures will put that in the manual. they don't want the engine live longer.
but i still don't trust those products
luc
Salinas Ca
1995 XLT 4WD
2016 XLT 4WD
"if its truly makes the engine live longer, of course all manufactures will put that in the manual. they don't want the engine live longer."
Sure,,,, another conspiracy theory.
Seriously, how can you say stuff like that?
If you had any ideas how products are manufactured and tested with a built-in life cycle, you would know that cars manufacturers have plenty of ways to design planned obsolescence without resorting to such a primitive, unsophisticated and unreliable way to achieve their goal
BTW, the main reason cars end up in junkyards todays is not the engine anymore so its really a moot point
182RG
Winchester, VA
'11 XLT / '13 Touareg TDI
Just wondering if you guys use Oil Treatment Additives for explorer
No. Waste of money. 6 qts of Mobil 1 5W-20 Full Synthetic can be sourced at discount for $30. I run it for 10K miles. Getting ready to turn 100K miles. Zero issues.
Black Eyed
Location
Saudi Arabia
Riyadh
I respect your point. but, compare new modern engines with old ones, it's not a conspiracy theory it's a fact. just a simple example: BMW now putting the their cars and external electric water pump. ok it's easy to replace but easy to fail and costly to change. i would say this is much better than ford they are putting the water pump almost inside the engine with plastic impeller !! Why the hell they do that ? well there is a lot of examples if we keep talking about it, this topic will go off topic with multiple directions.
Black Eyed
Location
Saudi Arabia
Riyadh
Thank you.
Our Ford dealer using 5W-30 because our hot weather. i'm also using Full synthetic oil.
reserved50
2013 Sport Exploder
stick with brand name synthetic oil and a brand name oil filter, Ford etc.
Bobs2018Explorer How the OEM Oil Cooler works, on a 2018 with the 3.5 V6 Stock 2011 - 2019 Ford Explorer Discussion 3
P Oil leak help!! Stock 2011 - 2019 Ford Explorer Discussion 3
B Loss of power & Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 3
R Lab-Chemical Fee Charged for Oil Change Stock 2011 - 2019 Ford Explorer Discussion 11
M Oil vapor smell Stock 2011 - 2019 Ford Explorer Discussion 1
G Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
E 5w-30 oil in a 3.5 NA Engine Stock 2011 - 2019 Ford Explorer Discussion 6
B Oil leak Stock 2011 - 2019 Ford Explorer Discussion 6
S 3.5L Oil Pressure Sensor Location Stock 2011 - 2019 Ford Explorer Discussion 2
J Explorer 3.5 NA Oil Pan Removal and Install Information Stock 2011 - 2019 Ford Explorer Discussion 1
S 2018 leaking oil Stock 2011 - 2019 Ford Explorer Discussion 3
K 2014 Explorer Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
B Proving Oil Changes? Stock 2011 - 2019 Ford Explorer Discussion 41
D 2017 Sport Possible oil leak? Should I be concerned? (pics) Stock 2011 - 2019 Ford Explorer Discussion 10
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
J 2018 Explorer Limited 3.5L oil leaks Stock 2011 - 2019 Ford Explorer Discussion 19
Jon M Using oil? Stock 2011 - 2019 Ford Explorer Discussion 7
R Oil Pump failure now have to replace engine Stock 2011 - 2019 Ford Explorer Discussion 22
C Oil leak leads to blown motor without warning Stock 2011 - 2019 Ford Explorer Discussion 45
O Does the 2013 Explorer Sport have a transfer case oil cooler? Stock 2011 - 2019 Ford Explorer Discussion 4
A Rear differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 10
Q Small Oil Leak - Passenger Side Stock 2011 - 2019 Ford Explorer Discussion 10
B Oil leak at start up in extreme cold. Stock 2011 - 2019 Ford Explorer Discussion 10
B oil line Stock 2011 - 2019 Ford Explorer Discussion 0
S ‘14 Explorer stalls in P with Low Engine Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 3
whitemage25 Low Oil Pressure warning at idle Stock 2011 - 2019 Ford Explorer Discussion 27
F 2011 Ford Explorer Low Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 5
E 2017 first PTU oil change and Mod Stock 2011 - 2019 Ford Explorer Discussion 7
C 2018 Explorer XLT Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 11
U Oil change in the wilderness Stock 2011 - 2019 Ford Explorer Discussion 27
D Oil press/Coolant temp/battery status? Stock 2011 - 2019 Ford Explorer Discussion 5
I 2017 Explorer sport, small oil leak, doesn't seem to get fixed. Stock 2011 - 2019 Ford Explorer Discussion 34
P 2013 Explorer oil leak Stock 2011 - 2019 Ford Explorer Discussion 2
N Engine Stall and Oil Pressure Warning While Parking Stock 2011 - 2019 Ford Explorer Discussion 5
O 2016 2.3L oil change too much oil? Stock 2011 - 2019 Ford Explorer Discussion 18
R First oil change for my explorer Stock 2011 - 2019 Ford Explorer Discussion 8
Eltee Resetting Oil Change Interval? Stock 2011 - 2019 Ford Explorer Discussion 7
Exit32 Factory oil filter dissection Stock 2011 - 2019 Ford Explorer Discussion 5
S motor oil debate. Stock 2011 - 2019 Ford Explorer Discussion 50
L 3.5L EcoBoost Turbo Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 13
H Oil Leak - Rear Ford Explorer 2013 XLT 4WD 3.5L Stock 2011 - 2019 Ford Explorer Discussion 8
S Front differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 0
C 2011 explorer oil problem Stock 2011 - 2019 Ford Explorer Discussion 19
B Front Engine Cover Oil Leak on Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
G 2016 Explorer Sport Jerking/Stall Cabin oil smell Stock 2011 - 2019 Ford Explorer Discussion 2
L Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
rok8man 2017 Ford Explorer Massive Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport oil leak? Stock 2011 - 2019 Ford Explorer Discussion 10
K New Noise After Oil Change Stock 2011 - 2019 Ford Explorer Discussion 8
B 2017 Oil Pan leak Stock 2011 - 2019 Ford Explorer Discussion 34
Similar threads
