does 99 XLS have OEM keyless entry?? | Ford Explorer - Ford Ranger Forums - Serious Explorations
z3r0_c00l
hey guys, i just bought my 99 XLS yesterday, i have one ignition key that wont unlock the doors, but i was wondering if there is a way to tell if i have keyless entry installed and i just need the remote. ebay has this remote plus programing instructions (http://tinyurl.com/ya9l5m). how can i find out if my X has keyless entry or not??
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
Just a tip on the exterior locks; spray some PB Blaster in them. Most of the time they lock up because the vehicle has keyless and the locks aren't used. I still can't get my hatch lock to function. Don't think the fobs are too expensive, get it and give it a try! :)
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
I don't believe an XLS has keyless entry. If there is no touch pad on the door, then it probably doesn't. My son got a used 2000 Mustang, the door lock was never used previously (apparently). We ended up having a body shop pull the lock cylinder out of the door and trunk and I took them to a locksmith to get them to work. (The whole story is much longer and doesn't bear repeating here.)
jp450
Pepperell, MA
'05 XLT V8
Try this... Turn the ignition key to the on possition then off 8 times. If the doors lock and then unlock you have the keyless entry module.
To program a fob do as above and after the doors lock and unlock press a button on your fob. If you have more than one press a button on each one. As you press a button the doors will lock and unlock indicating that the fob was programed. I think you can have up to 4 fobs.
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
you would have the number pad on the door if you have keyless
