Does a 1995 Explorer ECU have to be programmed? | Ford Explorer - Ford Ranger Forums - Serious Explorations
FordPickup
Boca Raton, FL
1995 Explorer
I'm replacing the ECU in my '95. At the last minute I saw a clause in the sales slip that said that the seller was not responsible for programming ECUs. I called the guy's attention to that, and he said that applies to newer ECUs, but my '95 won't have to be programmed. Is he correct?
koda2000
x
As the '95 is pre-PATS, I don't see why it would need to be programmed. No key codes to be programmed into it.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@FordPickup
Gen 3s have the VIN configured into the PCM or ECU. Not certain about Gen 2, but think it likely. A VIM mismatch between PCM and any of the other Modules, such as ABS, will result in ABS light constantly ON, cannot be turned off, no drivability problems from it, though. The DTC code "VIN Mismatch" will be found. imp
koda2000
x
@FordPickup
That may be true and I didn't think about things like wheel size and gear ratios.
