Does the BAFX OBDII Code Scanner with Forscan software display the transmission oil temperature for 2009 truck | Ford Explorer - Ford Ranger Forums - Serious Explorations
dB2000
San Diego
2009 XLT
Does the BAFX OBDII Code Scanner with a download of Forscan software display the transmission oil temperature for a 2009 explorer.
I ordered one from Amazon then I canceled it because I realized that most of the discussions on the forum were old and mostly talked about older explorers. I saw on the Forscan website that many of the scan tools did not adequately display some of the features any longer.
I did not see anything that directly addressed the transmission temperature nor my generation of truck, 2009.
Anyone on here possess any knowledge of the BAFX or any other code scanners having this capability. Something most desir which would be useful while towing a ailer?
Rcflyer330
Michigan
2010 Ford Explorer XLT V6
yes forscan will display transmission temp i dont know about the adapter. the odb adapter i recommend is an obdlink mx or any of the ones recommended by forscan. the mx isbnow the obdlink mx+ and i just checked and the price has gone up its ~$140 but well worth it in my opnion.
Here is the forscan page with the recommended adapters.
dB2000
San Diego
2009 XLT
oops, my touch pad sent this before I corrected my last sentence. I retyped the whole thing differently because I though the draft had been deleted.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
What about a Scangauge?
Rcflyer330
Michigan
According to BAFX's website the bluetooth obdII adapter is elm327 compatable so it should work with viewing transmission data with forscan.
Bazz270
Haifa,Israel
Ford Explorer 2007 XLT
Bluetooth adapters most probably wont read HSCAN bus.
For fully functional forscan diagnostic operation ,wired adapters (both MS and HS CAN capable)strongly recommended.
96eb96
Albany, NY
96 EB V6 OHV 4WD
Should read the Engine/trans computer fine. Other modules (e.g. The radio, etc) are on a different can bus, that can be another story. Probably better of getting a "Forscan" adapter with a switch or one of the ObdLink tools. This will let you access all modules.
