Does the Explorer Sport have an integrated oil drain plug washer? | Ford Explorer - Ford Ranger Forums - Serious Explorations
jeebus
Knoxville, TN
2010 Porsche 911 C4S
My wife's '14 Sport is coming up on 20k miles and I need to do an oil change this weekend. I did the first one but I don't remember if the drain plug has an integrated gasket. Anyone know offhand? Thanks!
Lethaldose50
Illinois
2015 Ex Sport
I just did the first oil change on my wife's '15 Sport at about 700 miles and don't recall seeing any sort of gasket on the drain bolt.
Sinister-CO
Highlands Ranch, CO
2015 Explorer Sport
It has a gasket but it's not attached to the drain plug.
jeebus
Knoxville, TN
Thanks guys. Looks like I need to swing by the dealership and pick one up.
jeebus
Knoxville, TN
No, I mean I need to pick up a gasket. For some reason I thought that the gasket was integrated into the drain plug.
*edit*
And it looks like my recollection is correct! Here's the drain plug image from Rockauto. The gasket is on the plug.
amd2800barton
2014 Explorer Sport
If you do your own oil changes, you might think about getting a Fumoto drain valve. They're awesome and make oil changes basically mess free. Also no need to change gaskets with every oil change.
Uaglio
2015 Sport
*edit*
you still sure that there's no gasket (it would really be referred to as a "crush washer" - an aluminum or copper washer)? That drain plug design doesn't always guarantee that no crush washer is used. I haven't changed mine yet so I don't know. Does anyone have a link to a parts schematic to see if a crush washer is listed?
jmr061
Wisconsin
16 Exp Sport
Everyone has access to parts schematics....www.fordparts.com
Uaglio
2015 Sport
Thanks for that. Diagrams show a washer for the 3.5l, but no part number listed for it. The 2.0l has a washer and a part number. The 3.7l seems to have no washer.
jeebus
Knoxville, TN
Just to close the loop on this....the Sport (3.5L twin turbo) engine has no crush washer. The flange around the edge of the drain plug contains a rubber gasket. There was no evidence of leaking as a result of the last oil change.
Dr Plastic
Newport News, Virginia
'15 Limited FWD
There is a seal molded under the flange of the drain plug.
Dr Plastic
'15 Limited FWD
Nice Find. I just ordered mine!
Uaglio
2015 Sport
Great thanks! Anyone know the torque spec on the Sport drain plug?
chartquist
Memphis, TN
2016 Explorer Sport
As a follow-up to this older thread, I'm about to do my first oil change. Does anyone know the proper torque setting for the oil drain plug on a 2016 Explorer Sport? Apologies if this has been discussed elsewhere.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
It has been asked before but no answer has been provided thus far that I have been able to find.
56_F100
Eastern Washington
2015 Sport
The drain plug torque according to the Ford manual for a 2015 Explorer Sport is 17 to 22 pound-feet. I have a 2015 Sport. The plug has an o-ring type gasket molded into the plug. The gasket seals against the oil pan before the plug gets tight. There is no magnet on the end of the plug (would be nice if there were). The hex head takes a 15 mm wrench. The plug itself has a m14 x 1.5 thread. OEM cost at dealership is around $10.
peterk9
Staff member
Moderator
Callsign
VE3
Good info, but the member you responded to was last seen here August 25, 2020. Others may benefit from your answer.
