I see!!
Well all he needs is a 99-01 5.0 rail, injectors and pigtails
Then his 2007 sender, pump and line remain.
Otherwise he will need to find a new 5.0L PCM donor and engine wiring change the transmission dtrs and CAm synchro, etc etc, fuel line from a v6 Ranger 98-07 with the correct cab and bed, and add the return line plumbing to his truck, sounds like a royal PITA
Trying to use a 99-01 PCM with a 96 engine and trans causes more problems, the EGR plumbing is completely different, the PCM went from analog (96-97.5) to digital (99-01) and so did much of the wiring and sensors. 96-97.5 = 5 wire mas, 99-01 = 7 wire mas. 96 cps 2 to 99+ 3 wire CPS, solenoid pack in the trans changed wiring, as did the dtrs sensor....you know where I am going with this. To keep the 96 stuff he already has and use it saves headaches.
I would rather just go snag the fuel rail, so many 5.0 trucks in the yard, craigslist or ebay
Hi, im doing a 5.0 swap into my 2007 ford ranger with the 4.0 I have just a quick question as I have everything I need my explorer im using is a 1996 which is return style fuel and my ranger is return less or will it do fine with the higher fuel pressure ?, seems like what I have read the ecu does not care on the 96 to 97 models I just want to know if I need to change anything in the fuel tank or will it power it up and just back pressure it into the fuel tank if the pressure gets to high please and thank you and to all who can help me with my question.
He asked "so if I get the injectors and fuel rail from a 99 to 01 do I need to change my fuel pump", the answer is you can keep your pump and plumbing with the correct parts
I plan to convert my 88 BII to returnless because my return line is kinked and I want to keep the fuel cooler for more power and better mpg
I have run 99-01 5.0L trucks with a 96 PCM for testing. You get lots of codes, but it runs.
This told me the 96-01 PCM all control the fuel pump the same way
So I researched it and it does.
Apparently the later model trucks like Gen V explorer have voltage modulation to the pump that regulates the fuel flow. Our early returnles systems do not.
PCM sends power to relay through inertia switch and fuse, exact same wiring from 96-01
