dacaur2
- March 12, 2018
- eagle mountain
- 2010 explorer XLT
Well, the title pretty much says it. front diver wheel bearings went out, so I have new ones on order (timkin) but not sure if I need a new axle nut. On my jeeps its recommended to use a new nut any time you remove it, but this is my first ford... If yes, can anyone give me a link to exactly what I need?
Also, my torque wrench only goes to 150ft/lbs, my jeep axle nuts are spec'ed at 175ft/lbs, but they dont put any kind of preload on the bearings, plus they use a castle nut and cotter pin, so going till it clicks then giving a bit extra (not with the torque wrench) has always worked fine. But I watched a video on an explorer and he said that the axle nut puts preload on the bearings on this truck so its important to get it to the right torque (185ft/lbs?). Is this true? Should i get a bigger torque wrench or is "tighter than 150ft/lbs" good enough?
