bartgillam
- February 19, 2012
- north augusta south carolina
- 1997 mercury mountaineer
I removed my front dome lights in my 1997 mountaineer and installed a single strip of 9 5050 white LED's. Extremely bright and looks amazing but i am wondering how do i make them work with the door open. I realize it has a double on switch one being the door open and one being the dome light button pressed manually. They work fine when i press the button but cease to work when the door is open. I am wondering what i need to do to resolve this. I connected the strips by removing the top console and soldering a positive lead to the red positive on both of the white switches and a negative lead on both the black wire on both the white switches. There is a white wire going into both of them which i assumed was constant power. Any help?
EDIT:: According to something i read a little bit ago the dome lights use some sort of ground circuit which i can only assume that the ground has 2 paths and the switch in the door activates one when open and one when closed..seems correct to me although i cant seem to figure out how to wire it up where it will work on both door and button switch.
