drbenz
- July 23, 2011
- High Point, NC
- 2000 EB 5.0
After beating my head against the wall for two days trying to find a broken wire in the driver's door wiring that was causing my dome lights to work only intermittently (when I opened the door the lights would go on and off as the door moved) I finally took the door latch out to check the switch to see if that was the problem. After way too long a time it occured to me that there is no dedicated ground for the switch, it has a chassis ground (the door). The long and short of it I installed a braided ground wire between the two sides of the door hinge and bingo my dome lights work as they should again.
