trucku
- January 25, 2005
- Queens, New York and living in Budd Lake, NJ now.
- 2002 Explorer XLS 4.0 4x4
Just the other day noticed that I could not lock or unlock any doors with button when the key was out of ignition. Locks worked when the truck was running. I wasn't too worried about it. Figured I would get to it when I get to it.
THEN: I attempted to defrost my window. My "Door Ajar" light came on and sound chimed.
My search lead me to this thread
Great info Synster!
Basically a wire broke between the door and body. The black ground wire from the door lock switch was severed.
During the winter my truck experience some "door ajar" issues. Now I know why it happened every time I hit a bump. I thought my hatch was not closing properly.
Here is thread to remove door panel.
Great info BigRondo!
Here is what I found:
Remove Door Panel !
I pulled the wire boot off the door to find a broken black wire that leads from lock/unlock switch.
View from inside door. I removed the electrical tape.
I was able to free boot from body and pull it into the door cavity.
Here is the wire as it would be in boot. Nice clean break.
Unfortunately I left my soldering iron at work along with my heat shrink. So I settled for a crimp connection and electrical tape.
Everything tested fine! So taped up my connection. Pulled the boot back into place and buttoned up door panel. FIXED!
Not a spectacular writeup, but figure I post something to help future searchers.
-V
Great info Synster!
Remove Door Panel !
-V
