Door ajar idiot light won't turn off despite all doors being securely closed
JRock23
PENSACOLA
2002 ford explorer xls
the door ajar lamp illuminates even though the doors are all closed. Where are the sensors for the doors located, and is there a fuse that controls this?
Donystoy
Hamilton, Ontario
02 Eddie Bauer 4.6
I have not had this issue myself but understand the door switches are on the latch mechanism inside the doors. Make sure that both rear hatches are closed. I inadvertently hit the upper hatch button on my key fob once. Drove me crazy until I found the problem.
fordysenior
True Northern California
2002 Expl 4x4 XLT 4.6L
I don't know of a fuse for them, but it's best to read for a code to tell you which door if it's not a fuse. If you do a search on this site, you'll find other comments about 'door ajar'. I purchased a Napa switch for my drivers door one, and it didn't work. Maybe the dealer is the best place to buy them. Other parts suppliers didn't have replacement switches.
gtyates
Location
Tennessee
Goodlettsville Tennessee
'09 Sport Trac, '17 Explo
Not uncommon. Spray some lubricant on each of the door latches. Had this happen on ours a few years back. Sprayed some PB Blaster lube, problem solved.
iowa_hick
Iowa
2002 Ford Explorer EB
I second what gtyates said. I had the same issue when I bought my Explorer and a little PB blaster straightened it out.
Blackhawkxx
S.W. Pa
2008 Explorer XLT
I have used WD-40 on the latches on my Ranger when it did this and it worked.
MartyD
Location
Atlanta, GA
Tucker, GA
'04 Explorer XLT 4x2
Get in , turn your motor on. Turn your dash light dimmer switch to the off position (make sure it "clicks"). Turn your dimmer switch back on (make sure it doesn't click at the top or you will have to do it all over again). This should turn off the door ajar light off. It won't solve the problem but...
A.Volkman
North Chesterfield,VA
2002 Explorer Eddie Bauer
Having this issue had the vehicle scanned and found out bad relay unplugged it and jumped the plug wires with paperclip to get it to shut up till the new relay thats what it called not a switch comes in from rock auto. Relay or switch can be removed from the latch assembly .
M2AAJr
Stanton
04 Explorer EB edition
Hello,
If you've tried everything that's been mentioned then allow me to point out that this is a common problem with gen 3 Explorers, Mountaineers, & Navigators. I recently fixed this same problem. In order to correct this problem you will need to take the inside door panel off the driver's side door (there are some really good videos on YouTube) & gently peel back the piece of foam, then locate the main wiring harness between the 2 hinges. Pull back the rubber boot & gently push it into the door. Now search through the wires & if you find a thin black wire(20-22 ga.I think) that is broke then you've found your problem. Usually it will be broke right in the middle of that bundle of wires. When Ford designed the wiring harness they didn't make that black wire long enough to allow for the door to fully open & over time that wire weakens & ultimately breaks. It's an easy fix but getting that boot out of your way is the hardest part. As I stated before there are some really good videos to help walk you through the necessary steps. Best of luck,
Tall-Paul-73
Villa Ridge
2004 Explorer V8 XLT
When I got my 04 Explorer none of the Windows worked and the door agar issue you have. Previous owner put in a new switch and had no change.
When I got it home first thing I did was pushed the boot into the door and found lots of broken wires. I added 1 inch to each wire using crimp on butt connectors.
Next day after shift I put down all the Windows. Previous owner who bought it with the condition and had it for 2 years was amazed in one day it was fixed.
Long way to say that you don't need to pull the door panel to check and fix the broken wire/s that you will find.
SixBucks
Near Charlotte, NC
04 XLT (RWD) 4.0L
Hello,
+1
I had to do this on my 04. I actually had two broken wires. It is a tedious job, not much room to work. Pack some patience and this will get you fixed up.
