door ajar issues
Mark Seaboldt
Orrick Missouri
2002 Explorer Eddie Bau
Need help getting GEM wiring Diagram 2002 explorer
domct203
Pilots The Beast
CT
2002 Explorer XLS
Check for broken wires in the door loom, this is a common problem.
My power windows suddenly stopped working, traced it to a broken ground wire in the door loom.
I have also read that a liberal dose of WD-40 into the door lock assembly can help flush out any dirt or corrosion that may give a false door ajar warning.
If you search the forum you’ll see the door ajar issue come up often.
Good luck.
Mark Seaboldt
Orrick Missouri
Checked front doors for broken wires and jumped all sensors still have issue that is why I am looking for GEM module diagram
