Door Ajar light problem in the winter or when it rains?
Fordman999
2003 Ford Explorer XLT
Just a suggestion if anyone is getting a door ajar light problem in their Ford Explorer in the winter or when it rains you might want to check if you have a sticking door switch. Then check for a bad ground wire on one of the door switches. If that fails check your rear window and rear hatch door switches. It is bound to be one of these issues.
dboogie2288
Indiana
2002 Explorer XLT
Yep..just resolved that today on my 02... Now to figure out why the drivers headlight wont fire up.... :\ :thumbdwn:
Fordman999
Make sure only 1 of your headlight wires is grounded. If both are grounded then you have a short on the second wire. Use a multimeter to check that and verify. Touch the lead to the wire and other lead to the metal of the car, if both leads give continuity then you will know for sure that is the problem.
