Ford_Lady123
- August 1, 2016
- 2002 Ford Explorer LImit
Having read lots of posts about the door ajar problem, I've not found my answer. The door ajar warning goes off randomly , driving down the road the door ajar warning goes off, doors lock/unlock and it also sets off the alarm, which drains my battery, because I took the horn fuses out, so I never know when the headlights are flashing in panic mode.
I have sprayed WD-40 in all the latches, opening and closing the doors for several minutes, I've taken off drivers side panel , no broken wires
This is what I tried next , I rolled down drivers window, turned key to the on position, then opened each door, one at a time, the back hatch and the back glass, all of them chimed and had the door ajar light come on on the dash , except for passengers front door, it didn't do anything, now after such a long post, trying to explain , my question is:
Is that my problem door ?? Thanks so much in advance
