Door handle touch unlock all doors?
ReLoaDeD BuLLiTT
13' Explorer Limited Eco
As of right now, when I reach my hand in the door handle, it only unlocks the driver's side door, which is inconvenient. I want it to unlock all 4, because my wife and kids are frequently with me. How can I reprogram it to unlock all 4? I'm sure it's possible. I was able to reprogram my Toyota to do it. Thanks in advance.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
fwrogg
Colfax, WI
2016 Explorer XLT
Not sure why the difference, but ours unlocks all doors when grabbing the handle.
Gatortailale
Reston, VA
2016 Sport
I think it is in left instrument cluster under my vehicle, then one on locks.
scarpi
Phoenix AZ.
2015 Explorer XLT 4wd
On my 2015, I don't have the keyless entry, and the owners manual says to hold both the lock and unlock buttons down on the remote for about four seconds and that will disable the two stage unlock feature. To enable it do it again. Yours might be different though since you have keyless entry. You might have to go into one of the menus on the touch screen or some other vehicle settings menu.
ReLoaDeD BuLLiTT
this did it! thank you! saved me the trouble.
vp6799
Massachusetts
2014 Explorer Limited
It's in the cluster under settings, then vehicle. I had to change it also.
ReLoaDeD BuLLiTT
I JUST bought this vehicle on Thursday, and it didn't come with a manual.
I did a search on this forum before making this post and nothing came up relevant to my question, so maybe this will help someone in the future. It's a limited, with the feature, why not use it? it's there for that reason. Countless times, I have things in my hands while opening my driver's side door and yes, it IS inconvenient to reach my hand in my pocket and grab my keys out and press a button versus sticking my hand in the door handle and pulling it instead.
#getalife
SickSix
Dirty South
2015 Explorer Limited
Wow, either you are really young, or it was REALLY inconvenient for you when you had to unlock the doors with a key and then unlock each door individually.
:nono: unnecessary
jarettp
2014 Explorer Limited 4wd
God forbid someone wants their $40-50k car to work properly. Guess me being really young is why I had an issue with my backup sensors going out. If only I'd been around when you had to use only your mirrors and best judgement. :rolleyes:
stever40
Location
Chula Vista
California
2018 Explorer Sport
I realize you already corrected the problem but just want to add that one might try pushing the last digit on the code twice. I know both my edge and F150 unlock all the doors if you push twice.
Ex. Code = 12345, Enter 123455. The 12345 will open just the drivers door and the 123455 should open all.
I am waiting for my EX so I don't know if it works on them.
ReLoaDeD BuLLiTT
god forbid someone wants their $40-50k car to work properly. Guess me being really young is why i had an issue with my backup sensors going out. If only i'd been around when you had to use only your mirrors and best judgement. :rolleyes:
lmao!
ReLoaDeD BuLLiTT
I just got it last week, so I haven't even programmed the door's keypad yet, lol. I was just asking about when i stick my hand in the door handle how it auto unlocks...it was only unlocking the driver's door, now it unlocks all 4. thanks! i'll keep that in mind as well.
stever40
Location
Chula Vista
California
2018 Explorer Sport
Yah, I mis-read. Sorry
ReLoaDeD BuLLiTT
Have you tried clicking the button twice? Thats how my Ford works. One click opens the drivers door, two clicks opens them all.
again, this is the feature you don't use a remote or a keypad for, it's for when you simply reach your hand in the door handle. it worked fine double tapping the unlock button on the remote. whether or not the feature is only with the limited, i could not tell you. i got it sorted though. :)
Bigbman
2016 Explorer
Intelligent Entry Frustration
When I first got my 2016 Explorer, the key fob/intelligent entry unlocked all of the doors when I touched the driver's side door. Now it is only unlocking the driver's side. The dealer says that is the "correct" way it should work but I want all of the doors to open. Can I change it somehow?
Britta-S
Chicago, IL
2016 Explorer Sport
I don't know about the correct way (did you look it up in your manual? even though that doesn't mean too much either...), my 16 unlocks all doors when I touch the driver's side door handle.
TBill
Prescott, AZ
2020 Explorer Platinum
Unlock all doors
There is a setting in the left hand display that will allow you to unlock all door with a touch of the inner button on the driver's door. It's under vehicle in the information display.
TBill
Dr Plastic
Newport News, Virginia
'15 Limited FWD
Yup. That owners manual is very informative!
C Door handle 2016 Stock 2011 - 2019 Ford Explorer Discussion 1
D Interior door handle - chrome coming off Stock 2011 - 2019 Ford Explorer Discussion 8
S Drivers door Intelligent Access door handle not working Stock 2011 - 2019 Ford Explorer Discussion 12
Trader0000 Read Door Handle and Latch Stock 2011 - 2019 Ford Explorer Discussion 2
J Anyway to unlock all doors with door handle(driver side)? Stock 2011 - 2019 Ford Explorer Discussion 3
A Door handle removal Stock 2011 - 2019 Ford Explorer Discussion 2
J auto door handle lock unlock not working Stock 2011 - 2019 Ford Explorer Discussion 0
J Automatic door unlock via outside handle Stock 2011 - 2019 Ford Explorer Discussion 4
O Door Handle Insert Stock 2011 - 2019 Ford Explorer Discussion 5
L 2013 Driver Exterior Door Handle Replacement Stock 2011 - 2019 Ford Explorer Discussion 8
L Weird encounter when lock door using door handle Stock 2011 - 2019 Ford Explorer Discussion 0
D Door locking from door handle 2016 Stock 2011 - 2019 Ford Explorer Discussion 9
T Explorer door handle recall Stock 2011 - 2019 Ford Explorer Discussion 4
X Interior Door handle LED out Stock 2011 - 2019 Ford Explorer Discussion 2
L 212,911 Ford Explorers (2011 - 13) recalled for door handle issue Stock 2011 - 2019 Ford Explorer Discussion 18
M 2012 Driver Door Handle Sticking Stock 2011 - 2019 Ford Explorer Discussion 8
V Door Handle Lock Stock 2011 - 2019 Ford Explorer Discussion 12
U Chrome Door Handle Part # Stock 2011 - 2019 Ford Explorer Discussion 3
G 2019 XLT Outside rattle, Top left driver side door Stock 2011 - 2019 Ford Explorer Discussion 9
T 2017 Explorer drivers door unlock issue Stock 2011 - 2019 Ford Explorer Discussion 3
D 2016-Need to calibrate blend door actuator after replacement Stock 2011 - 2019 Ford Explorer Discussion 1
C Keyless door entry pad - explorer 2011 Stock 2011 - 2019 Ford Explorer Discussion 0
S 2016 Ex Passenger Door Unlocking and Alarming with No Keyfob Stock 2011 - 2019 Ford Explorer Discussion 0
M Door lock issue Stock 2011 - 2019 Ford Explorer Discussion 2
Sentry6 Fender alignment to door Stock 2011 - 2019 Ford Explorer Discussion 1
G Parasitic battery drain with lift gate and door open? Stock 2011 - 2019 Ford Explorer Discussion 7
R How to adjust door gap? Stock 2011 - 2019 Ford Explorer Discussion 3
B Vibrating when foot on brake and closing door Stock 2011 - 2019 Ford Explorer Discussion 5
M Blend Door work Stock 2011 - 2019 Ford Explorer Discussion 0
M 2016 Explorer power door lock issues Stock 2011 - 2019 Ford Explorer Discussion 7
M 2013 Ford Explorer Dash Noise\Grinding-Not a blend door I think Stock 2011 - 2019 Ford Explorer Discussion 3
S 2015 Explorer Shudders when in park , running and a door closes Stock 2011 - 2019 Ford Explorer Discussion 12
Michael W 2018 Explorer Platinum Rear Door Won't Open from Inside Stock 2011 - 2019 Ford Explorer Discussion 0
F 2014 Explorer - Door Lock Issues Stock 2011 - 2019 Ford Explorer Discussion 3
M Hazard lights and door open error went haywire while driving Stock 2011 - 2019 Ford Explorer Discussion 6
A Remove Exterior Lower Door Panel Stock 2011 - 2019 Ford Explorer Discussion 6
R Door Lock (Relay) Issues Stock 2011 - 2019 Ford Explorer Discussion 22
T Explorer door sill Stock 2011 - 2019 Ford Explorer Discussion 4
ddaniel13 Rattle in Door Stock 2011 - 2019 Ford Explorer Discussion 3
N 2016 front door 6x9 mounting depth Stock 2011 - 2019 Ford Explorer Discussion 1
N Stolen Keys / Door Lock Replacement Stock 2011 - 2019 Ford Explorer Discussion 20
T Intelligent Access Problems: Drivers Door Unlock Stock 2011 - 2019 Ford Explorer Discussion 8
R 2014 Door Keypad Stock 2011 - 2019 Ford Explorer Discussion 3
R Door Lock Beep? Stock 2011 - 2019 Ford Explorer Discussion 10
H 2014 Explorer Driver Door Lock Actuator Replacement Stock 2011 - 2019 Ford Explorer Discussion 5
Jon M Right front door rattle Stock 2011 - 2019 Ford Explorer Discussion 6
wharriso Is It Possible to Lock Out the Garage Door Opener Unless the Motor is Running? Stock 2011 - 2019 Ford Explorer Discussion 10
D 2018 gas door? Stock 2011 - 2019 Ford Explorer Discussion 3
B Hole in Blend Air Door on drivers side 2011 XLT Stock 2011 - 2019 Ford Explorer Discussion 1
A Power windows and mirror buttons do not work on drivers door Stock 2011 - 2019 Ford Explorer Discussion 2
Similar threads
