door jam codes?
Braydon
West Haven, Utah
93 xlt
I was looking at my explorer's door jam sticker and I want to know what my spring code is. It says "w u" under the spring column.
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Well, this is useless as is, but maybe you can take another step:
From the '94 chassis manual:
W: Front, part# F17A-5310-AFA
U: Rear, part# F17A-5560-DC
I guess it would be nice to have spring rates and such, I'll look around.
Good Luck!
Braydon
West Haven, Utah
93 xlt
ahh makes a little more sense ha thanks
F 2 door 4 door doors Stock 1991 - 1994 Explorers 4
D fixed the back door that wouldn't open. Stock 1991 - 1994 Explorers 0
Exploring XLT Empty plug between passenger and rear passenger door Stock 1991 - 1994 Explorers 4
massacre Pass Front Door Lock Stock 1991 - 1994 Explorers 12
D passenger rear door won't open. Stock 1991 - 1994 Explorers 0
massacre Rear Drivers Door Lock Actuator & Plastic Piecebrok Stock 1991 - 1994 Explorers 4
massacre Door LatchesI Stock 1991 - 1994 Explorers 31
D drivers side door hinge pin Stock 1991 - 1994 Explorers 2
8 Door striker nuts fell into body Stock 1991 - 1994 Explorers 6
R My power door locks don't work. I had to replace the locks. Now the power door locks don't work Stock 1991 - 1994 Explorers 24
7 Door problem Stock 1991 - 1994 Explorers 6
L Door lock / Handle Stock 1991 - 1994 Explorers 1
RustyMacintosh Broke the drivers door handle--94 XLT Stock 1991 - 1994 Explorers 5
massacre Is There a Glue That Works on Door Panels? Stock 1991 - 1994 Explorers 7
I 1994 Eddie Bauer 4 door Stock 1991 - 1994 Explorers 0
O 2 door quarter panels Stock 1991 - 1994 Explorers 0
Z Door strike help! Stock 1991 - 1994 Explorers 2
A 93 Explorer Driver Side Door Latch Malfunction Stock 1991 - 1994 Explorers 4
S Help: removing rear door windows and regulator. Stock 1991 - 1994 Explorers 1
RangerX Best brand/source for replacement door handles? Stock 1991 - 1994 Explorers 10
J Door handles Stock 1991 - 1994 Explorers 6
I Does 1992 Navajo Fender Fit 1993 4 door Explorer Stock 1991 - 1994 Explorers 5
yostyexplorer94 Door striker bushings Stock 1991 - 1994 Explorers 2
X 93 explorer sport door hinge replacement Stock 1991 - 1994 Explorers 3
B door vibration Stock 1991 - 1994 Explorers 5
C liftgate interior door panel Stock 1991 - 1994 Explorers 2
C Will 4 door & 2 door fenders swap ? Junk yard says no ! Stock 1991 - 1994 Explorers 9
D Door banging Stock 1991 - 1994 Explorers 8
T 2 door interior door handles Stock 1991 - 1994 Explorers 1
G Door and Tailgate Latch Stock 1991 - 1994 Explorers 1
J 94 Explorer 4 door limited, I may have killed my transmission. Stock 1991 - 1994 Explorers 7
FirstExplorer Power Door Lock Question Stock 1991 - 1994 Explorers 4
T Door lock and window switch illumination? Stock 1991 - 1994 Explorers 3
kmack How to remove door window trim? Stock 1991 - 1994 Explorers 1
7 Rear Hatch Door Stock 1991 - 1994 Explorers 5
T interior door panels Stock 1991 - 1994 Explorers 5
B 91 XLT door chime Stock 1991 - 1994 Explorers 5
S Dome light won't come on w/any door open. Bad headlight switch? Stock 1991 - 1994 Explorers 0
O Door Lock Actuator Troubleshooting Stock 1991 - 1994 Explorers 3
T outside door handles loose Stock 1991 - 1994 Explorers 9
S No power door locks Stock 1991 - 1994 Explorers 5
I door weather stripping Stock 1991 - 1994 Explorers 3
O Replacing rear hatch/5th door Stock 1991 - 1994 Explorers 1
Z 93 XL 4 Door 4x4 explorer weel bearings Stock 1991 - 1994 Explorers 9
R 1994 Explorer 4dr rear door issues Stock 1991 - 1994 Explorers 6
C broken tailgate latch, door shut Stock 1991 - 1994 Explorers 3
davy crockett Source for door panel armrests? Stock 1991 - 1994 Explorers 10
S door ajar/ interior lights Stock 1991 - 1994 Explorers 9
B 2 door / 4 door Stock 1991 - 1994 Explorers 1
P Pattern for door handles? Stock 1991 - 1994 Explorers 30
Similar threads
