Jason94sport
- April 30, 2001
- FL
- 04 EB V8
FL had a cold spell. My X didn't like that. The passanger side door lock wouldn't unlock. Heard the motor. Key also didn't work. I left it alone. Seemed to be fine once the temp went back to normal. Forward now almost 2 months. I discover the passenger door will open from the outside when locked. I can use the keyless remote & I hear the motor & the knob does go down like it should be locked. Normal lock & unlock sounds. But I can open the door from outside. I lock with the key same thing. Any ideas? I'm terrable at anything but taking the panel off. I'll give it to a shop if I need t replace a actuator or linkage.
