bigredexplo88
- June 17, 2010
- Ohio
- 97 Explorer XLT
My driver side door lock will not lock on its own when using the power lock button, also the lock cylinder on the outside seems to jamb up when trying to unlock sometimes not all times however if i turn with force it will unlock. i have found the culprit, however i cant think of anyway to fix it. i belive the actuator is Mounted to the door using a Rivet. However the rivet head is broken off and i belive my actuator is jamming the rod inside the door. Just wanted to get some input on this. Anyone else have this problem? What was your Fix? was tinking about just putting cold weld on it to hold it up but not sure if itd work. Can i Rerivet?
See Pictures Below
(Note Picture was taken on Passenger Door Just to use as reference to what i need on Driver Door)
See Pictures Below
