yob_yeknom
Moderator Emeritus
- November 14, 2000
- Glade Hill, Virginia
- '97 XLT & '06 Limited
I just got new Pioneer speakers for my doors. They handle 50w RMS and 180w max. I am thinking of getting about a 50w RMSx4 channel with the closest to 180x4 channel max amp I can find to make them louder. I am going to use the factory speaker wires coming from the head unit to plug into the high level inputs on the amp. I would then run wires from the outputs on the amp back into the factory wires to the speakers. Will the factory wiring going to the door speakers be big enough to handle the new 50w+ of power coming out of the amp without burning up, or will I need to run bigger wire from the amp to the speakers? I REALLY don't want to burn down my new toy, but would hate to go through all the trouble of pulling out factory wires and running new wires if I don't have to. (I like to make things look as close to factory as humanly possible even if the only way you could see it was to take out panels.)
Also, should I spend all the money to buy Dynomat for inside my doors or just spray on some rubber undercoating or maybe just some thin carpet padding (which I can get for free)? Keep in mind I will be adding some serious speakers and amps in the cargo area when I get the cash. Plus, what should I use to soundproof then?
