Door Switch LED Conversions | Page 2 | Ford Explorer Forums - Serious Explorations
and now my interior gauge/door/ac/ etc lights dont come on. any ideas? what fuse would this be? what a ****ty ####ing mod this is turning out to be.
AND to top it all off, now it doesnt start. great.
I like it... might do this myself when it isn't freezing out... even in the garage it's too cold lol.
better change your post because the positive side is NOT the side with the two tabs.. just like the stock button its on the other side.
if you look, it was changed.
are the switches like the instrument panel and have that green film, or do they shine whatever light you put through them?
just fyi the positive side is on the side with the one tab...just went and did all my switches, just to find out they are all wired backwards. Might want to change the post.
Hey, I tested doing this with my 2001 Sport Trac and have run into an issue. Im using the same size LEDs as stock, and just soldered them directly into the old spots. And when I hook the switches up to harness again they dont light up! Do I need to remove the resistor even though they are the same size as the old LEDs?
start by making sure your polarity is correct. if it is, then try putting in the resistor that the l.e.d. came with, as well as a new l.e.d. if that doesnt work, you have a problem elsewhere.
I got it all working ok! Guess I had a couple bum LEDs that weren't working correctly!
Messed up the Driver window switches tho. Gotta wait to buy a new board to proceed
Great stuff! Thanks for inspiring me to do this! I just did my 2 front doors. Driver's side on a 4 door eX is easier to do because its a cluster of switches instead of individual ones. (see picture below(sorry about quality, I didn't set up macro on my camera)) and pictures of the finished product. I got my LEDs from ebay, $4.40 free shipping from somewhere in asia, hong cong, I believe. For the cluster, I didn't bother replacing the resistors, wasn't sure what ohm to use, but they work fine so far.
Did you have any kind of problems with the master switch when you did this?
Hey I ran into some trouble with converting the master switch to LEDs and I could really use some help. I soldered in the LEDs just like B3hr3n did and I can only get the "auto" light to stay lit out of all the 8 LEDs. I can get some of the others to light up momentarily when I put a lot of pressure on a certain area of the switch but I don't understand why because all my solders have a good connection from what I can tell and the 2 springs inside also have a good connection and are making contact where they should be. Anything you have about this issue would really help me out. Thanks!
recheck everything. if you have power when you push down, you have a bad contact someplace
I thought I'd share my main switch pictures for anyone who wants them. When I did my first switches(the other doors) I used new resistors. But when I did this main switch I left the factory ones in and just installed my LEDs. I don't know if the factory ones will last but I guess we'll see. Definitely worth doing. I hope this helps. Any questions just ask! And thanks to vroomzoomboom for the write up!:thumbsup:
LEDs are from SuperBrightLeds
and are RL5-R5015: 5mm Red LED
Separate the switch
This is the bronze that you don't want your solder connections to touch
I took a small screw driver and pried the small white lever out which will pull the switch apart
Do that for all of them and it should look like this
Drill pilot holes the old led holes. I didn't remove the green leds, I let the drill do the work.
Now insert the new LEDs. On my 98 XLT(not sure if there all the same) The positive is on the right side of the switch as pictured for the right side. And on the left side the positive runs on the left side.
I soldered in the first LED.
Here you can see that the longer side of the LED is on the left side as I mentioned earlier.
Here are all of the LEDs soldered in. Excuse my soldering I'm not a pro by any means lol
I took this picture in the day. Sorry. But they are brighter and better in person.
Any one willing to make me some I will pay for them money order or PayPal .
they will shine what ever color you put under them.
Do the rear switches light up also? My front switches light up but not the rear, so I'm wondering if the rear is just burnt out. If I wanted the rear to light up, could I just replace them with front passenger switches that I pull from other X's?
i dont have a 4 door, but i have made rear switches for some people here
Ok. I Swapped out my front switches a year ago since mine had water damage, so I guess the rears are just burned out since they're the originals. That's what happens when you run your parking lights in the day and all the interior lights are constantly on :D
Well I found out something very interesting today, I pulled some switches from an Eddie Bauer at the local junkyard and they illuminate just fine when I bench test them, but it seems that my 2000 XLT doesn't have the pins for the lights in the window switch harness. It's not too much of a problem as I can just wire it myself. I just found it strange when my truck already has wiring and fuses in place for a bunch of other features that weren't included from the factory.
