uchi
- June 22, 2007
- niagara falls ontario
- 2001 sport
ive been playing with the search feature on here and ofund a ton of info regarding the door locks. generally its them being slow to unlock or taking a few presses and then open. thats my pass side. gotta push the lock manually to lock it and itll unlock on its own. which is funny because last year it did the opposite. the problem is the driver side door. it started to act up this winter and wouldnt unlock even with the keypad and now im noticing that even when i try to use the key its just feeling like it turns halfway and seizes. ive watch the door flex a little as ive tried to force it to unlock. usually i just start pressing the unlock button on the keypad while i fiddle with the key and most of the time it works. but i usually end up standing there looking like a dumbass. so once we finally get a day that isnt freezing i want to pull the door panel off and see if i can grease something up and im hoping its an easy fix. so far ive shot probably a quarter of a can of wd40 into the lock trying to get it to fix itself but the problem hasnt been fixed. so my question is this, what am i looking for when i get the door panel off? and what should i lube up? ill bathe everything in there in grease if i have to, but i want to make sure i dont miss anything. thanks
