Dorman Lower thermostat housing and Sensors | Ford Explorer Forums - Serious Explorations
Stick_man
NYC, NY
1998 Explorer V6 SOHC
Coolant leaking from thermostat housing. Ordered a Dorman off ebay.
I take it from all the reading I did on this that the Dorman are screw in type sensors, and the stock oem are held in by circlip of some kind?
Where do I get Dorman ones that will fit their housing?
I didn't buy that housing that you linked to. Mine has screw in sensors. I assume those are oem style and push / pull is not. I thought it was the other way around.
Did you see the RockAuto link above with threaded sensors? IIRC, Dorman does not offer them for their own lower housing.
