BuffaloXplorer
The X had to go!
- April 5, 2004
- Buffalo, New York
- 2006 Impala SS
DPFE Sensor or EGR Faulty? Help!
PLEASE READ!!!!! HELP!!
:fire: I've been stuck with a p0402 (EGR Excessive Flow) for quite some time, and have replaced every component within the last year (maybe 8 months). Each repair seems to eliminate the problem for a while, but then the CEL comes back. I'd reset the CEL, and it'd be off for a day, maybe two. Now, it's back before i reach my next destination. Something in the system is seriously wrong!
I think it's either extreme carbon buildup in the manifold pipe or a bad dpfe sensor (existing sensor is approx 8 months old).
According to Haynes, i can test the DPFE voltage to determine it's functionality. There are 3 wires in the harness: signal, ground and something, maybe power (?) and they're lined up top to bottom.
I'm not sure which is which, though, so i do not know which to test. Unlike other connectors (i.e. TPS), Haynes does not show which wires to connect to. It says to backprobe the harness when connected to the sensor, but with my straightpins i cannot get a consistent reading (they're thicker and i think they're not reaching the actual wires. I may try poking the wires with sewing needles and attaching alligator clips, b/c i need to work the throttle too.
The components involved in the EGR system are the Valve, DPFE sensor, EVR (vacuum regulator), manifold pipe, dpfe vacuum hoses and evr vacuum tubes. Is there anything that i am forgetting, or that could possibly cause this code?
