Drain plug upgrade
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Ford says the plug is a 1 time use so that delicate plug UPR states is supposed to be replaced each oil change.
I do like their idea (I reused my plug and dont see anything about it that is delicate). I would love something designed like the fumoto valve so we dont ever have to remove them.
Mikey*TX
Location
Liv'n in the hollow of an 'ol oak tree. ;-)
Skunk Hollow, TX
2020 EXP ST Blk
UPR 3025-01 is the same w/o the drain tube feature. $10.00 less. I prefer the twist to open feature. I can direct the old oil right into an empty 5 qt jug with no mess. Ditto the last qt into another empty jug. Put them into empty plastic pickle buckets for transport to the recycling facility.
No mess, no fuss !
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I collect the oil for a waste oil burner that heats the shop, cant recycle any better than that lol.
Mikey*TX
Location
Skunk Hollow, TX
2020 EXP ST Blk
Gotta agree. Used to simply pour it into the fuel tanks of the county heavy equipment. No more. EPA pulls spot checks now. Off road, ag fuel has a different color than highway. That's what they look for. If they don't see the correct color dye, then they really get into the fuel analysis thing. A former TXDOT regional dept head got caught a while back. Hence, the word former ......... :D
Mikey*TX
Location
Skunk Hollow, TX
2020 EXP ST Blk
So glad that happened after I pulled the plug. CID got brought into that mess as the investigation went statewide. Sucks imho
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Looking at the site that was linked, I don't see anything that says it can be used on the 2020 Explorer.
Carbon87
2020 Explorer XLT
Are we talking about the normal oil drain plug here? It is a one-time-use plug? If, so, wtf is that about?
  • Like
Reactions: imp
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Yes, it is supposed to be a 1 time use plug. It is a plastic plug with an oring. It isnt supposed to be reused once you remove the plug/oring.
Carbon87
2020 Explorer XLT
I've seen some dumb sheet lately with cars. But a disposable drain plug? Get out of here with that crap. Is there a reason that anyone has seen from Ford for this, other than essentially close to doubling the cost fo an oil change (if $8.19 is a representative price)?
peterk9
Staff member
Moderator
Callsign
VE3
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I did my first oil change and reused the plug. I did order a spare prior so I have a new one on hand but figured I'd see how it went reusing it. So far no issues.
peterk9
Staff member
Moderator
Callsign
VE3
I'm can't really answer that. I've only seen what was posted in that thread. I did some Internet searches and the picture in on this particular site seems to show an aluminum replacement. I don't even know what I have on mine since I haven't been under it to check but I'm guessing it's plastic. It looks like that if you have that yellow plug, then the oil pan will be plastic.
themishmosh
NE Ohio
2020 Explorer ST
I would think if you continue to reuse the OEM or buy an aftermarket that after 2 or 3 oil changes, you are going to want to change the O-ring(s). Whether they are available for the aftermarket ones, I don't know. Planning to use the OEM for 2-3 changes and then swap in the brand new OEM one.
Spacey
2020 Explorer ST
If the pan is plastic, I suspect that using a metal plug has the potential to strip out whatever fittings are on the pan. If the thing is only $8 it seems like cheap insurance to get a new one with every oil change. Maybe the bigger issue is the likelihood of a plastic oil pan getting damaged in real world use.
Similar threads
