gto78
- June 18, 2006
- stuart, fl
- 98 EB 2wd v-6
I am in the dead center of HELL :fire: right now. I started off with a really loud clatter in the timing cover. Took it off and found the tensioner broken in pieces. I replaced it and the chain- but when i loosened the bolt for the jackshaft sprocket, the cams BOTH moved. NOW i have to find the cam positioner tool and line everything up and start over.
So far i removed both oil pans, replaced the pan gaskets, replaced the lower front chain and tensioner, and reinstalled the oil pans. NOW i have to rip apart the top of the engine and access the cams so i can realign the cam and then resecure the bolt for the jackshaft sprocket. WHAT A NIGHTMARE. THANKYOU FORD FOR YOUR DUMBASS DESIGN. I am impressed with this engine at the same time as I want to smash it with a sledge hammer. It performs great, but was designed by a total P O S moron who obviously doesnt work on engines. I cant believe how many hours I'm wasting doing the absolute simplest job- changing a timing chain.
WTF FORD?
WTF FORD?
