Walrus
- July 24, 1999
- Ft. Payne, Alabama
- 1998 XLT 4x4
Been a while since I have lurked around here... Good to see the board is quite active!
I am looking for a little assistance with my 98 4dr 4x4 xlt. My power door locks are no longer unlocking with the driver door switch. Here's my research so far:
Switch is good. Removed switch, used a volt/ohm to verify continuity. Ground is good. I removed the wire that should be continued to ground when the switch is pressed and shorted it to ground... No unlock. I measured for voltage at the lock wire... 12 volts. I checked for voltage at the unlock wire... No voltage.
I got out my haynes manual, wiring schematic shows 3 relays in the aux relay box#4. I opened up the jack storage panel, and found the relay panel there to include 2 larger, and 2 smaller relays. I swapped the two larger (could feel one click when door was locked), and still no unlock from driver door. I did not mess with the two smaller relays.
Anybody got any idea?
Well, after further searching (using various iterations of power lock, etc) i have gleaned a bit of info that I'll put to use. I am still looking for info on which relay is the driver unlock?
Any ideas?
Thanks in advance...
RM Smith
Walrus
Any ideas?
RM Smith
Walrus
