Tike
- May 10, 2017
- Greater Philadelphia
- 08 Ford Sport Trac XLT
So i've been noticing more and more vibration while driving at 45+mph speeds... even on brand new roads. went under the truck and found this at the center bearing on my drive shaft.... are these replaceable or what?
other symptoms i am having are: Rough engaging of first gear from a slow coast or stop (random) Squeaking when starting from a stop/ switch between drive and Reverse. and what feels like a studder or bad shift in a higher gear. similar to a TCC not engaging properly.
i attached the picture. The red circle is wear it is all torn and their is a lot of side to side play in the shaft. (NOT rotation, that has normal amount)
08 ST XLT
08 ST XLT
