E.T.
- December 30, 2018
- Ucon, ID
- 2004 Explorer XLT
Hullo all.. I have a low frequency noise somewhere in my drivetrain. Sounds IDENTICAL to the one I had before, which turned out to be a U-joint. Having just replaced the other u-joint it's still there, so has to be something else. I do get diff whine when decelerating (so that's needed replacing for a while)- could it be a worn bearing going into the diff? Something in the transfer case? I'm at a bit of a loss. The frequency is low enough that it only just becomes audible at about 60mph. Cheers!
