ranman106
- August 12, 2008
- north carolina
- '97 XLT
Ok guys, I searched on door lock and read through 404 posts! I did not find anything on my problem. Here are the details.
1997 Explorer XLT
Power door lock switch on drivers door will not Lock or UNLOCK any doors. Passenger door lock switch, key fob, and the keyless entry all work properly.
No voltage at switch on pink/green wire or the pink/yellow. Both pink/green wires in the door sill beside the driver seat read 12 volts. If you ground the p/g wires in the door sill, all doors will unlock (but not through the switch).
I have not found the splices yet. I plan to remove the passenger door panel and swap switches to rule out a bad switch.
Any ideas?
1997 Explorer XLT
Any ideas?
