thegoon543
- January 24, 2000
- Cary, NC
- '10 Escape Hybrid Limited
i have not posted in quite some time but glad to know this resource is here.
for a while, the driver side puddle lamp would turn on with the other interior lamps when i'd open a door or unlocked with the remote as normal. then it started going out when i opened the driver door, only to turn back on when it was all the way open. now it doesn't work at all (all other lamps work). i tried replacing the bulb, but got nothing.
i suspect a frayed wire going to the puddle light, but trying to sort through the large wire bundle going to the door seems difficult. everything else on the door works except the unlock side of the lock switch (unrelated, i think). i've pulled off the wire boot b/w the door and body but cannot see anything obvious. i know the wire to this puddle light is black with a pink stripe, but not sure where it would be frayed. i'm hoping to fix it w/o having to remove the door but don't know where to start looking.
