koda2000
- September 2, 2011
- x
Some of you may recall a problem I had with an alignment shop installing camber/caster adjusting bolts and plates on my daughter's 2000 Mountaineer about a year ago. The issue was that the plates kept moving and throwing her alignment out. I had the original alignment shop re-adjust and re-tighten the bolts once and a few months later I noticed that they'd slipped again and it ruined 2 good Michelin LTX tires. I got the alignment shop to give me a deal on 2 new tires, but I took the truck to my regular alignment guy for an alignment. I made sure he tightened the hell out of the bolts after getting the truck in alignment, but it appears the alignment has slipped again (not as bad as before, but the tires are wearing more on the inside and the steering wheel is no longer quite centered).
The shop that did the original alignment had said that they couldn't understand why the alignment kept going out and that there must be something wrong with the truck. I called BS on that because we had put 60,000 miles on that truck since we bought it and never had any alignment or tire wear issues with the OE control arm bolts/plates. The only reason I decided to get an alignment was because I replaced the upper and lower ball joints. I've had 4 Explorers/Mountaineers aligned at my regular shop and they never needed to install C/C kits to get the alignment w/in factor specs.
So now I'm thinking that perhaps the issue is with the alignment plates or bolts the tire shopped used. I don't know why they decided it needed adjustable caster/camber bolts/plates on the driver's side only, or what quality of kit they installed. Now I'm thinking maybe I should go back to stock OE bolts and C/C plates (either that or Moog C/C kits). This truck has never been in an accident or had problems before the alignment was done.
Does anyone who has installed C/C kits still have their original OE bolts and plates that they're willing to part with? Or do you think I should buy the Moog C/C kits and have them installed?
Someone here suggested I double nut the bolts or but Locktite on them, but that shouldn't be necessary IMO. Maybe it's the grade/quality of the bolts?
