I did mis-state this. It is not when I approach....It is when I touch the door handle where the problem begins. It just started happening about 2 weeks ago. I triedthis with both key fobs with the same result.Welcome to the Forum.
Are you saying that when approaching the Explorer the door lock unlock by themselves? If so, that is very unusual and abnormal I believe. Normally you have to touch the door handle if not using the fob. I've never had them open by themselves. Is this something that just started happening? Have you read through the Manual about the setup regarding the locking/unlocking of the doors?
Check to see that the settings for the door openings have not changed. I doubt they have since the driver's door is affected in all cases. I wonder if it could be the door actuator not 'seeing' the 'signal' from the fob and the handle since it seems to work with the interior manual switch. I don't recall this issue coming up here before.I did mis-state this. It is not when I approach....It is when I touch the door handle where the problem begins. It just started happening about 2 weeks ago. I tried this with both key fobs with the same result.
I will check the settings for the door opening.Check to see that the settings for the door openings have not changed. I doubt they have since the driver's door is affected in all cases. I wonder if it could be the door actuator not 'seeing' the 'signal' from the fob and the handle since it seems to work with the interior manual switch. I don't recall this issue coming up here before.
Once it is open, are you able to lock it with your fob and the touch pad? Have you also tried the keyless Securicode pad to see if it unlocks/locks the door?
I think maybe there is some sort of Body Control Module which would send a signal from the remote to the door lock?Can you confirm that you hear it(feel it) trying to unlock the driver's door?
If so, might not be the actuator itself, but the connection between the actuator and the lock.
I have the exact same problem on my 15 Limited. Anyone find a fix?Hey all,
Have a 15 Limited that the drivers door handle wont lock or unlock the doors when I grab/push handle. Passenger door and rear hatch work fine.
Welcome to the Forum.I have the exact same problem on my 15 Limited. Anyone find a fix?
Yes, fob works fine, door pad works fine, hatch works fine, passenger side intelligent access works fine. Just the driver's side handle button and inside of handle won't work.Welcome to the Forum.
Are you able to lock/unlock the door with the Securicode keypad, the door switch and fob? As far as I know, no one has reported a fix.
