Kidd7
- January 13, 2014
- RTP, NC
- 2000 X AWD EB 5L
On the new to me Ex I've been working on the drivers side door lock buttons would not work. After some research here I found that those are wired separately from the pass side and there have been issues with these wires breaking in the door jam. I opened that connector and pulled back the rubber sleeve and sure enough those 2 wires were completely broken and bout 4 more wires had the sheathing cracked with corrosion on the wires. There was also evidence of moisture being in that sleeve. The wires were so badly corroded that even cutting back an inch or more that wire would not take solder. For all 6 or so wires I found damaged or broken I cut back a few inches on each side and soldered in a new jumper. Attached is a pic of what I found when pulling back the sleeve.
For what its worth, I removed the door to have more room to work, it was a pain to reinstall, but I think worth it for having so many wires to repair.
