smutheop
- July 9, 2005
- Putnam CT
- 95 XLT
Just bought a 95 XLT with keyless entry on the drivers side and the only lock actuator that will not work properly is the drivers side. It will unlock with the remote and keyless entry but to lock it I have to use the key. My mechanic says I need a new actuator and not just a two wire. Is there an aftermarket? available or can I use any actuator from any model of Ford with keyless entry? (Junkyard would be $10.00 but explorers are far and few between in junkyards around here) Or is there the possibility that the actuator is good and something mechanical may be wrong with the mechanisms? Thanks....
