Driver's Side Headlight Not working | Ford Explorer - Ford Ranger Forums - Serious Explorations
cousinoc
1998 Ford Ranger
My driver's side headlight decided to stop working. I've replaced the bulb and ballast (I'm running HID's in the low beam in an aftermarket assembly). It started out as just the low beam on the driver's side then the high beam went out also. I replaced the multifunction switch. That didn't fix it. I bypassed the headlight switch by jumping the pins. That still only made the passenger side light come on. All the fuses are good. However, I checked the amps coming in to the fuses and fuse 4 which is the fuse for the driver's side is only getting .025 amps where fuse 8 (the passenger side fuse) is getting roughly 6 amps. So I'm not sure exactly what that means. Any help on this would be greatly appreciated.
smithn1997
1997 edii
Most likely will be the light outage module its located under the console of the information center is this an eddie bauer?
TAdams
Pacific NW
1997 Explorer EB
I had the same issue with my 97 at roughly 119,000 miles. I did not have any aftermarket lighting, and it turned out to be the LOM as Smighn1997 stated. Basically the wire routing makes a turn/bend and places a lot of pressure on the connector that is soldered to the breadboard. Over time, the solder connections fail and removal/disassembly of the LOM and re-soldering fixes the issue.
