Driver's Window Control Button
Reynolds1961
Chatham, IL
2002 XLT 4X4
I have a 2002 Explorer and I need to get to the auto window switch to replace it. Does anyone have any tips on how to get the switch panel off the door without destroying it.
Thanks
aldive
Elite In Memoriam
1999 XLT
Not sure on an '02, but on my '99, I have to remove the panel from the door to get at the switch.
Good luck .......
White97Jimmy
Detroit, MI
2013 Dodge Charger RT AWD
I just removed mine 2 days ago. I just pulled...there are tabs underneath, this is what they look like:
Cdaddy78
Canton, OH
'02 XLT
Pull out on the trim around the door handle first. Once that is off you can just lift up on the trim around the switches as the picture shows. That order will prevent any breakage
