Driveshaft dillema - double cardan joint | Ford Explorer - Ford Ranger Forums - Serious Explorations
Dre
Chicago
2013 Explorer Interceptor
I'm starting a driveshaft overhaul. When was double cardan joint introduced in the Explorer?
I want to rebuild it but now can't find parts... everyone says that I should not have double cardan on my 94... what gives?
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
You definitely have a double cardan Joint (2 U-joints at one end for greater range of movement) in the front drive shaft.. here is a picture of the double cardan U-joint in my ('93)
Dre
Chicago
I know I do but for some strange reason when I order parts them guys keep telling me that double cardan was only available on 1991-1992 Explorers...
well, did anyone overhaul this? does spicer have a kit available?
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
Dre
Chicago
nice job with the write-up. Someone should stick it up here for all the rest. So all front driveshaft U-joints are the same???
I might want to use spicer 1310's then...
I'm working on the entire front end - Skyjacker lift, gears, locker, ball joints, brakes, u-joints - the whole 9 yards...
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Kick that guy in the shins and run away with the U-joints :thumbsup: :p:
Dre
Chicago
I've got some time, I can order on-line. Would rather go with the Spicer stuff... although NAPA sells Precision u-joints - believe it or not it was NAPA guy that didn't want to listen to me...
and could not find right u-joints in his smart computer :rolleyes:
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
Yes.. The front and rear drive shafts use the same U-joints, while the front axle shafts use the "C" clip 1-0297s..
U-Joints (Brute Force)
Wheel Joints and axle slip joint (3) 1-0297BF
Front Shaft (3) 1-0153BF
Rear Shaft (2) 1-0153BF
Sounds like you have quite the little project going on.. IMO its better to just do everything at once instead of having to revisit other areas a few months down the road..
ericautopart
Jersey Shore
1998 XLT 5.0L AWD
I've got the parts too if you need them..
Dre
Chicago
well, I'm looking to order Spicer u-joints and looking for a new locker... the one I've got is for the later IFS diff...
ericautopart
Jersey Shore
1998 XLT 5.0L AWD
Just PM me w/ a tag # or somthing for the front diff.
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
I've got some time, I can order on-line. Would rather go with the Spicer stuff... believe it or not it was NAPA guy that didn't want to listen to me...
Tell that parts store putz to grab the DANA catalog they have sitting behind the counter. Blow the dust off it and open it to the apropriate year, make, and model. I can almost guarantee the catalog has the numbers you need in there.
I don't trust the computers at the chains for nuthin'. They're notoriously inaccurate. Garbage in = garbage out.
-Joe
Dre
Chicago
I did find part numbers myself... not the first time I have to do the homework before going shopping. They don't care anymore...
