Glasken
- December 16, 2014
- Wisconsin
- 1993 Ford Explorer XLT
Hey guys, oddball question for ya:
Would it be possible to add a double cardan cv h yoke to the transfer case side of the rear drive shaft in a 1993 4 door explorer?
Stay with me a second...
So I did a SOA conversion, and because I didn't check my math when we welded the new perches I have about a 7* positive angle on my pinion (pinion is pointing up at the xfer case). My rear driveshaft is a conventional double yoke, which means there will be some issues with the angles from the xfer case to the pinion being different.
The late Broncos and early 90's f150s have a double h yoke on their driveshafts. Can anyone think of any negatives to adding such a yoke to the xfer case side of my driveshaft to eliminate the pinion angle issue (rather than cut and reweld the perches, which would be the correct thing to do). Adding the new h yoke would also have the effect of a spacer to shore up any reach issues with the SOA.
The H yoke from a Bronco or early f150 has the same dimension bear cap holes and snap rings as the first gen explorer: http://www.dennysdriveshaft.com/p975_ford_cv_h_yoke_1330_series.html
Looking forward to your opinions, thanks!
