coyoteddie
- March 26, 2006
- show low, az
- 01 sport trac
Is it possible to disable the DRL's (Daytime Running Lights) on my 2001 Sport Trac
on mine their's a slider type roll switch which on the rear view mirror.
i didnt know 01 sport trac come with daytime running
lol that wasn't me that post that danny it was my friend sorry bout that. He is kinda out of it right now he is lil bit drunk.
Umm, ok? Are you few real!? After 91 or so all cars trucks and SUVs had to have DRL to be road leagle...In Canada...
what's a leagle....![]()
what's a leagle....
edit: you could probably disconnect the park brake input to the module from the harness, and connect it to ground (going into the module), think this will fool the DRL module .
I finally got hold of a wiring ski matic and it was as simple as pulling the plug from the DRL module. And by the way there is a sticker under my hood that says "this vehicle was manufactured for export to Canada" As far as legal or illegal doings :bsnicker:
My next project is to get the Bright lights and fog lights to stay on together. :shifty_ey
Thanks all
Are you going to share with us are do we have to pay for that info?
If you just disconnect the DRL module (which is located behind the drivers bumper with the connection facing down) the "BRAKE!" and High beam indicators apparently do not function properly.
Also as simply stated by someone that if you pull the brake cable a little it shouls go out-- wrong. These da#$ DRL never go out.....unless.......here it is....all for free...:
Clip the light green and yellow wire going into the DRL module. This cuts power to the module and disables the DRL without the annoying warning lights. Plus it saves wear and tear on my expensive bulbs.
