soujern
- June 22, 2002
- Minnesota
- '91 XLT
Hello,
I've been lurking on the board for a couple weeks now.
'91X - 135,000miles - Auto
My X has the famous won't start on first try but starts right up on the second after it primes a again.
I put a fuel pressure gauge on the schrader valve today and turned the key to run (not started). The pressure climbed to 40 but rapidly went back down to zero.
I then started and the gauge showed a steady 30.
From what I read using the search feature this is not the regulator but the check valve inside the fuel pump.
I don't believe you can just change the check valve but have to drop the tank and replace the whole fuel pump.
Also theres a buzzing coming from the fuel tank....kinda like when you open the door and the key is in the ignition.
So is it time to replace the fuel pump???
Or should I look somewhere else for the soulution?
Please let me know if I'm headed in the right direction.
Thanks alot!
Thanks alot!
