DTC C1234 Missing sensor help! | Ford Explorer Forums - Serious Explorations
jallara
2002 Explorer XLS
Short time lurker here...so, I got the DTC for replacing a bad speed sensor. Sensor has been replaced, code erased, but now I get DTC C1234 for a missing signal. I tested the resistance on the new sensor and the sensor is good. What next? Do I need to replace the hub?
TIA,
Jenn
A bad hub can cause a sensor fault.
Ordered a new one...I'll let you know how it goes...
Replaced the wheel bearing hub assembly today...FIXED! Man was it a ***** though! After 12 years of rust...damn thing did not want to come out!
Nice! Always good when things work out.
